I am guessing that with 14 psi, you got an aftermarket (stock is usually run between 5 and 10psi) but if you didn't it's not good enough.
The factory lift pump is, well, just in a bad location. It has to prime from dry, that's why they wear out. But another thing is that the relay that controls it is inside the PCM (I'm pretty sure) and the aftermarket setups do two things to correct these problems. 1. Mount the second/aftermarket on the framerail where they don't lose their prime. 2. Operate off a seperate relay taking the load off the PCM relay so you don't have to replace your PCM or crack it open to replace the relay. At least get a relay between the factory power and the lift pump.
By the way, the reason you got an actual vacuum is that there is a diaphragm pump inside the vp that helps move the fuel. It is not adequate on it's own, though. At least that's the way I understand it.
