you should absolutely have a fuel pressure gauge, way more important than any of the other gauges
Put your truck details in your signature.....i am about to buy and install an edge ez should i install a Fuel pressure gauge? i already have a boost, pyro, and trans temp... but i wanted to know if i should get the fp gauge and which ones i should buy lets see some pics too! thanks :confused013:
Looks like you need a new lift pump. 6psi at idle is a little low:thumbsup:This is my Glowshift on a column mount. It is electrical and cost about $60. You should get whatever brand matches your others, though.
Don't know that I'd waste my time with a light. Generally they don't come on till the fuel pressure has dropped below 5psi which is too low according to the FSM. I'd stick with the gauge.and if not a gauge at least a fuel pressure warning light. you can get them for like 30 bucks
:ditto:I prefer mechanical...never trusted electronic gauges. tapped banjo is the best. when i was still using banjo bolts I had the tapped one hooked up under my stock fuel filter canister connected to the line that directly feeds the vp44. now I have an airdog150, so all of the banjo's are gone and its pulling right off the gauge port on the airdog pump.
I installed my Aidog 100 Saturday night, now it's a constant 20 PSI and has a lot more power.Looks like you need a new lift pump. 6psi at idle is a little low
