1 - 2 of 2 Posts
PA CHAPTER VP
I just put in my new airdog 100 less that a week ago and had to re route my gauge pressure tap. Gauge was working fine reading a steady 15-6 PSI but today i took a glance and it was dead 0. I dont know what happened. Is there anyway to check to see if the gauge is dead? Or could it be a possible pinch in the pressure line going to the gauge?
Steve
I would be really suspicious that the wiring is loose or something. It got fooled with and it doesn't work now, so look at what was done. If you hear your pump run, it's probably got pressure. It's pretty hard to pinch off a line, and your truck wouldn't run if you did. Might take a look at your fuses just in case.
1 - 2 of 2 Posts
