With normal driving the fuel pressure will stay around 10 lbs. Recently my fuel pressure gauge has started fluttering or bouncing when I accelerate or when the truck is under a load. When it bounces it will go from about 6 to 20 lbs. and fast enough that it is kind of a blur. When I let off the accelerator the gauge is rock solid again.
Things I have tried:
I have connected a test gauge to the schraeder valve on the VP44. (both gauges bounce)
New fuel filter. (no change)
Different lift pump. (no change)
Wired the lift pump directly to the battery. (no change)
Different overflow valve (the banjo bolt that fastens the return line to the VP44). (no change)
Could it be in the VP?
Any ideas or suggestions?
Bucky
Bucky
