hi guys,
i'm sure you have answered this question a million times, but the only reason i ask is because you guys know your stuff and i don't trust any of my local shops! i need to know what size fuel plate i should use with a stock fuel system? i need a little bit more power when towing. thanks again guys!
hi guys,
if you have a stock trans...nothing under a 10 plate, if you want it to hold up for long. atleast a VB and TC
would you be able to go a bit more if its a manual?? in another year or to im moving back to the states then hopefully buy my dads 02 if its still in ok condition and i will want to put all the mods on it. at the moment im just dreaming about it. what can i do to get it around 4-600 hp? and how much will that hurt my wallet?
then you dont need to worry about fuel plates being that you are getting a 02. the mechanical p7100 only came in cummins motors from 94-98.5 enjoy the electrical side of diesels with a 2002
Tech Specialist
1994-1998.4 ... In 1998.5 is when the 24 vp trucks began.
As far as 400-600hp ... Thats a BIG difference in numbers there. I was at 400 ... and am currently in the middle of my 600+ build ... and it is NOT easy on your wallet. You gotta pay if you wanna play
how is that build going?
