1 - 12 of 12 Posts
I want to put a fuel plate on my 95 2wd automatic. What size would be best not to tear up the stock transmisson but give me some good power??
SC Chapter President
Is your truck auto or 5 spd? I would assume its 5 speed.
He says in his post that it's an automatic. For a '95 auto TST Products recommends a #6 if the transmission is stock. If it's modified to be able to stand more power a #5 is ok.
I have a #5 in mine with a modded valve plate and billet TC. No problems in about 75K.
wow, i dont know what i did, but when i slid my stock plate just 1/2 way my trans started slipping pretty good well at least the t/c and now just waiting for a few thousand dollars to float my way till i can afford a fully rebuilt heavy duty trans:CRY::$:
:rof The early trucks will not have a good trans for long with a # 6 plate
So what do you recommend if a #6 is too much?
The # 10 is very versitle and will work excelent with a 3kgsk kit.Adding the gsk will allow much better drivability and make the trans easier to live a longer life
Bob
Tech Specialist
The power level of the plate is also greatly dependant on the position of the plate. And trans life depends on how you drive. I agree that a #10 is a good plate, and think its the best for the street
thanks ctd5.9 for the charted info :thumbsup:thumbsup:thumbsup:thumbsup:thumbsup
The chart does not show you how they fuel-ie rpm(power band) :peelout
1 - 12 of 12 Posts
