1 - 20 of 31 Posts
Can any body share with me what they are getting city highway with this set up if you have it?
Mopar1973Man.Com
I don't have it... But...
I know you should be able to clear 20 MPG rather easy...
I normally clear 21-23 MPG with my setup...
Not to be rude...
I need to know Fuel Mileage with 6speed and 4:10???
Can anyone chime in that has the config?
On call 24/7
Every truck will be different. Tire size, 4x4, 2x4, how you drive, mods and ride height all factor in.
Mopar1973Man.Com
Not to be rude...
Help you out just a little bit...
Final ratio of...
5 Speed is 0.75:1
6 Speed is 0.73:1
Auto is 0.69:1
So either manual tranny is the same...
So anyone with a 4.10 gear setup will do for you...
Final ratio of...
5 Speed is 0.75:1
6 Speed is 0.73:1
Auto is 0.69:1
I respect you knowledge...
But in laymans terms what does this mean?
If I have 4:10's what can I do to increase fuel mileage?
K
Guest
i average 18 mpg 50/50 city highway i can but it up to 20-21 all highway and all interstate around 17 all city driving hard and smoking like crazy the worst i can get is 14mpg
K
Guest
drive around 1700-1800rpms thats the sweet spot for mileage
i also have a 6speed 4.10s and 285/75/16 procomp xtreme mts
Discussion Starter #10
At those rpms what speeds can you hit on the freeway?
Your tires are not much bigger than stock?
I appreciate all you guys help:yourock:
K
Guest
also when driving be very light on the throttle and keep boost low as possible to get the best mileage
Discussion Starter #13
285s are 33s thats running 55mph
2000rpms 65
2200rpms 75
what do you mean 285's are 33's?
Are your tires stock size? I'm confused by the whole thing. JUst trying to figure out how good/bad the mileage would be and what I can do to improve it with mods.
On call 24/7
Stock size is a 245/75/16, roughly a 30 in tire. 285/75/16 equals a skinny 33 in tire.
K
Guest
tires are 33inches tall they are 285/75/16 measuremnt
i think stock size is 265s they are smaller than the tire i run
Mopar1973Man.Com
In laysmans terms it does matter if you got a 5 or 6 speed they both twist just as fast in high gear...
If you want good high MPG number is rather simple. If you got both boost and Pyrometer gauges... "keep your boost under 5 PSI and Pyrometer under 600*F and 20+ MPG will happen"
Here is a write up for MPG's for ya...
Better MPG's
I had a 02 6 speed with 4.10s the best i could get was 14 city and about 10-11 hauling up to 14,000lbs.
Discussion Starter #18
How about on the highway?
Also, do you know of anything that can improve MPG with the 4:10's
Discussion Starter #20
stay around 1800rpms and keep boost as low as possible
What was your mileage on the highway?
I was told that putting taller tires would change the ratio
and improve mileage. I am looking at a beautiful truck, but it has 4:10's. I'm buying it as a daily driver, I don't tow or even use as a work truck. Have always wanted one and hate to pass this one up. It's a nice one owner 56K, Medium Bronze with black leather Laramie. It was used by a wealthy women to tow here ponies around.
There is no way for me to improve mileage on this truck with these gears?
1 - 20 of 31 Posts
