My truck leaks fuel from the top of the tank,somewhere, has anybody elses truck do this? It starts with just a quick turn of the key and runs fine, I just cant seem to find out where it leaks from.
1ST GEN MODERATOR
The tank sending unit is held in by a plastic ring that screws onto the top of the tank. See if it has unscrewed for some reason. It is sealed by a big O-ring.
There are also a couple of vent hoses that go into the fuel sending unit.
The sending unit does seem kinda loose, is there any for sure way to see exactly where it is leaking? I have tightened every clamp so they are fine.
1ST GEN MODERATOR
Have someone pressure the tank and watch for fuel coming out.
If no fuel comes out feel around it for air coming out.
How much psi do you recommend?
1ST GEN MODERATOR
About the most you need is a couple of psi in the tank.
Mine leaks also. First time i top her off, i must of spilled a gallon on the fuel island.The gasket/ O Ring is available from Dodge.
