Strange fuel leak under intake manifold rubber line with hose clamp drips constant when running. Any help?
That's return from over flow valve.
Common with as old as that rubber is getting.
Put new hose on all the way to the fire wall.
5/16 if I remember right. The FSM has all those details.
Get some marine grade material. It's a real PITA to change that stuff if you have a brake booster and the original fuel filter setup.
5/16 is correct. Needs to be diesel-rated.
