1 - 1 of 1 Posts
So I pulled the fuel return line and it was new...fuel looks like its leaking from the back of the injector pump, but is also leaking on the side of the block. I have no idea where it's coming from???:banghead: My fuel shut off solenoid also wont pull the shaft back up, but if you push it in it will stay up with the key on and lets go when you turn the key off. It takes quite a few times before it will start, gonna change the fuel filter tomorrow. It had black gunk in the bottom of it with the consistency of bearing grease. The previous owner had loosened the fuel shut off arm that runs through the pump and connects to the shut off solenoid, so I dont know at what angle the arm is supposed to be at...The groove is what im going by for reference...:confused013: O yea the fuel heater has been deleted
1 - 1 of 1 Posts
