ok guys first i thought the leak was comming from my rail but i think i found that its comming from the bottom of my cp3. my truck wasnt leaking any fuel then i removed the cp3 and the rail and put them back on and had a leak. i couldnt find the leak comming from the rail so i checked the cp3 put my hand under it and my hand was soaked in fuel. so my question is, is where can fuel be leaking out of the cp3? can it be leaking from anywhere or is there only a couple places 4 a cp3 to be leaking from? i would rather not take the cp3 off again and put it back on to fix the leak so is there a couple things i can just re tighten and check or should i just take it off clean evgerything and put it abck on? thanks 4 the help guys.
