I have a liquid which appears to be fuel in my oil. My prior tank I made 18+ mpg like normal, but they past tank only made 10 which is why I believe its fuel. Problem is, I'm told fuel shouldnt float above the oil.
Oil is black with 3k miles on it
No loss in power
Antifreeze is where it has been for months
I took valve cover off and seen no unusual spray
the level of oil thats black is between Safe and Full, Above that is a lighter texture liquid with a black clear tint
Injector lines are tight
Temp gun to the exhaust manifold shows all tempts are close to each other at idle after 20min hard run
Pry bar to head and ear show no signs of knocking or irregular sounds
How possible is it to have a leak from the Injector pump, 163k Stock pump with a Airdog to it.
Got Edge at 140k and pressure was 5 at idle and 0 if stepped on throttle. As of now I dont know fuel pressure until I get the Edge attachment since cant find old one which came with Edge/Att.
No loss in power
