Since the FASS system mounts in an exposed area under the bed, are there any concerns regarding cold weather? Does the fuel gel?
With the correct fuel and additives, this has not been an issue. Now in some extreme climates (Canada and AK), filter blankets and running coolant to the FASS can help.Since the FASS system mounts in an exposed area under the bed, are there any concerns regarding cold weather? Does the fuel gel?
There is a desert in California that has temps of -20F or lower in the winter?We go to the desert in the winter and temps get deep into the negatives.
#2 with the correct additive will be just fine....do some research as i really dont have ONE suggestion. I dont worry about my fuel (IF im running #2 instead of Bio) until about 0*......it dont start to cloud (I think) to about -5 to -10......We go to the desert in the winter and temps get deep into the negatives. I'm just worried that I'll have a load of #2 and wind up freezing up somewhere. When you say correct fuel are you referring to #1? I've never seen #1 where I fuel up. Also, what additives are you referring to? Thanks.
