1 - 10 of 10 Posts
What causes the low fuel light to come on? A sensor in the tank or does it come on when the gauge drops to a certain point? I am just curious because usually it comes on when I have about 4 gallons left and yesterday it came on and I drove a little bit and filled up and there was still 7 gallons in the tank. When does your low fuel light come on?
when i have low fuel.
jk, but it's usually at about two gallons for me.
Were you on level ground when it came on?
It works off a float and because our tanks are very long being off level even a little bit is a big difference when you're low on fuel.
Yeah, Im pretty much always on level ground. And it comes on and stays on. You would think even if it came on because you were on a hill it would go off once you leveled out.
· avatar challenged
2021 DRW CCLB 4X4
My light comes on different times on mine, like when im towing heavy, it will come on sooner. I just figured the computer was reading my fuel usage was greater and it comes on earlier then it does when im not towing anything. I dnot know for sure tho!!
1 - 10 of 10 Posts
