1 - 16 of 16 Posts
i just joined the site, i just got my second cummins 97 and the fuel gauge doesn't work. it just lays over on the empty line with the fuel light on. also the cruse and the horn doesn't work. :confused013:
can you help?
Just normal for these TRKS ..drop the tank replace sender
fuel pump
thanks,so you dont think it could be a ground? do you have 2 replace the whole sender or just the guts?
Mopar1973Man.Com
You just replace the sender... The rest of the guts you re-use...:thumbsup:
It's about $70 bucks for a sender... Easy to do I did mine in 1 hour...
Where can i get one of these sending units. I have searched all over and can only find the unit that has the integral pump which i dont need. I just need the sending unit. Help:banghead:
The float on mine disintegrated and fell off. My buddies did the same thing. He bought a new sending unit and I lucked out and found a whole new module on ebay for $35. So probably a new sending unit would fix yours.
Mopar1973Man.Com
Like I said its a dealer only part and ask him for only the fuel level sender. My dealer in Ontario, OR keeps about 5 of them in stock at all time. They run about $70 bucks. This is WITHOUT internal pump or basket... Just the sender...
what error codes did ur guys truck throw when you had to replace the sender?
Mopar1973Man.Com
No error code here... other that I was running out of fuel and the gauge was showing over 1/2 tank...:doh:
Thank God for the Drawstraw sucking air was clueing me in that I was really low on fuel...:shock:
I had an error code from starting the truck without the plug on the sender, but no code when it was just faulty. I paid $54 for the sending unit at the dealer.
Iv got the same problim. I just havnt had the time to fix or get it fixed.
mine acts up as well. goes to a wacky level then to empty, i just go by mileage for now till i get bored and want to replace it. only that that gets annoying is everytime the gauge drops off, it chimes...
I had a code with mine. Don't recall what is was but it was about miles not matching up with something. :confused013: :confused013::doh:
Got the same code a wile back. It was saying that you cant drive "X" amount of miles without the fuel gauge not moving. If i remember correctly
Yeah, that sounds like the same one I got.
can you help?
I'm having the same problems too! My truck is an 01 though
1 - 16 of 16 Posts
