I'm interested in improving my fuel system also. I'd be interested in parts numbers and suppliers and a detailed write up of what you end up doing.
Thanks.
Will do!
Will be 1st week in Jan, though. Retiring from my current job in the Vegas area and going home to SE MO, then will put on the filtering.
Going to add in a good filter / water separator mounted on the frame in line between the tank and the oem filter, and install a small micron CAT fuel only filter between the oem filter and the CP3 injector pump.
I'll make up my own line / fittings for the pre-oem separator, and might get the GDP (Glacier Diesel Products) "Big Line Kit" which provides a larger full size 3/8" line from the oem filter to the CP3 inj pump. Will have to get a couple more fittings to insert the post-oem CAT filter in that line.
EDIT: Just discovered there's a restrictive small line from the line on the frame (from the tank) up to the filter inlet. Of course there's a GDP kit for that, too.
http://www.glacierdieselpower.com/product.aspx?pf_id=9852-0509-FIK&rurl=
Here's the "big line kit"
Glacier Diesel Power - Product Detail
Now we're up to $100 for the 2 larger line kits, might have to check out individual fitting and hose pricing. Instead of the kit from the frame line to the filter, might just adapt to the steel line coming out of the tank and put all larger fittings and line thru the separator and right up to the oem\ filter. Summit racing has a pretty good selection, depends on where you are you might find them locally, too.
The first one from the tank will be a Fleetguard FS 1212 filter / separator. (FS denotes Filter / Separator) Spec'd at 20 microns filtering, but most importantly over 90% of free and especially important emulsified water. That will mount on the frame under the truck.
Then it'll go thru the updated oem filter which knocks it down to 5 (or 7?) microns absolute, plus is also a good water separator, then to a CAT 1r0751 filter which is either 2 or 4 microns depending on what you read.
Then from the CAT filter to the pump using the rest of the Big Line Kit which has a fitting to hook up a gauge, and a snubber to dampen the pulses.
Auto Meter AM-3279 fuel pressure snubber-Geno's Garage
Everything is available at Geno's Garage - except for the CAT filter which from what I read is the smallest micron filter available, nothing quite so small from Fleetguard, and maybe that Big Line Kit. That kit is not a bad price when you start pricing individual AN fittings.
The Fleetguard filter head is 142784S. Wix makes one that might be just a little easier to mount to the frame 24770. Link on the below page.
Fleetguard 142784S Fuel Filter Head : Amazon.com : Automotive
Going to talk to them Monday and will get everything lined out with what they can provide, then get the rest (CAT filter, additional fittings, etc)
Amazon.com: Caterpillar 1R0751 Fuel Filter: Automotive
Hope that helps for now.
I guess you need a compression to AN hose barb fitting setup to get from the 3/8" oem hard line coming out of the tank, thru the filter / separator, and back to the hard line.
AN thread - Wikipedia, the free encyclopedia
AN Fitting Thread Size Chart
Hope that helps - took a LOT of research to get what I would consider reliable info on all the different available filters - you can have "nominal" micron filtering efficiency and "absolute" efficiency which is the one you want to look at. You also also need to keep in mind adequate filter flow so you don't starve the CP3 inj pump. These filters are not far under 100 gph.
From what I've read the stock in tank pump will adequately supply fuel to the CP3 thru this setup. It's not high pressure (something like 5 psi?) but has pretty high flow capacity.
