Should be a yellow lever on the side of the bowl. Push it open and it will drain. Once fuel stops running out just close it back off.
When you look at the fuel filter housing, you will see a hose. Put a catch pan under that, right above that you will see a yellow valve push or pull it and it will drain the fuel filter housing.
I actually have to crack open the cap to get fuel to flow out of of the tube. Easy job though.
:agree2: I changed mine today and it helped when I cracked the lid. Finally got my Baldwin filters in :thumbsup:
