1 - 4 of 4 Posts
my fuel filter canister leaking from the water valve drain,,,, is there a simple fix for these drains,,, 98 12 v
simple fix it just threads into the bottom of the canister. just go to the auto parts store and get a new fuel filter and change the filter depending on if the leak is from the o ring or the actual drain you may need to buy a new drain if fuel is leaking but the new filter will come with and oring if thats the issue
Or you can use a Napa 3395 filter that has no valve hole.
I figure since none of my tractors or other diesel trucks have drain valves why should the Dodge.
1 - 4 of 4 Posts
