yep....one reason i bought a FASS. to answer your question though....yes you can rebuild the drain, but i am no help on this with links or part numbers. it's a pretty common issue to have this happen.My fuel release valve on the side of my fuel filter canister is leaking out of the bottom and top of the lever. I was wandering if anyone else has had this issue I figured I would take it off and see if there's a bad O ring. Any other info would be greatly appreciated !
