Couple questions for you all.
1) On the 4th Gen radius arm trucks, is the front shock what initially stops/limits the droop of the front suspension? I am pretty sure it is but want to confirm.
2) For those of you who have done front leveling kits, assuming the shock is what limits droop, and having the truck in the air with the suspension at full droop that is limited by the extended shock length, after taking out the bottom shock bolt, how much further(measured in inches), would you say the axle has to drop in order to have the coil spring unloaded?
