Talked to Dave (SledNeck91604) and he said he may know a builder for the front pans. I would really like to snag one since no one else makes one and I'm going for a sleek classy look for my 92 restoration and don't really want to go with a big oem bumper. (I started this one because the old thread was closed)
- Dev
As a thought...
The early to mid 70's trucks had a much smaller and sleeker front bumper. You could find and cut one up. I think that would have the right curves for what you are thinking of doing.
Sure wish I knew where I saw it now but someone on here posted a picture of a 1st gen with the smaller gasser bumper they had recessed in to sit more flush with the front of the grille. Not really my style, but looked good on a lowered 2x4
- Dev
Just keep in mind that you still will have to have some sort of actual bumper, by federal safety standards. Its legal to run just a roll pan on the rear of a pickup, but not the front. That being said, as long as your custom bumper LOOKS like a roll pan, you're good to go. :)
Chrome Front Bumpers | 1972-93 Dodge Truck 1974-93 Dodge Ramcharger | LMC Truck
I don't mind the top bumper, but its for a 1972-1982 pickup. Should still work right?
Yes and no. Keep in mind that there are 3 different pictures on that page.
That 1972-1982 bumper is what I was thinking of in my previous post. However, the bumper mounts are different. I put a mid 80's cab on my 1975 w200. The bumper from the 1985 bolted onto the frame as I recall. However, the bolt holes for the bumper were different. I ended up putting the older style bumper on my w200. The reason was I have a plow on front that uses the bumper bolt holes for mounting. The holes were in the wrong place on the mid 80's bumper. With a welder and drill this difference could be adjusted.
I would look on Car-Part.com--Used Auto Parts Market for bumper brackets and perhaps a bumper. Shipping on a bumper could be expensive because of its length.
Thanks guys. Keep the suggestions coming. Please. I will update with progress as well. Trying to decide on a grants kustoms steel rear roll pan or a d150 fiberglass pan. Your thoughts?
Bonded on fiberglass will not rust.
Welded on or bolted on steel can and given time will rust.
