I have a 3500 4x4 and am wanting a front hitch. So far I have not been able to locate one... anyone know if the 2018 Curt will fit? Others? Thank you!
If you give me the measurements from center to center of your inside tow hook bolts and then the spacing for the bolts on each tow hook I can measure mine and see if it's the same.
I drove a new truck this morning. No way will the old front hitch work. Tons of stuff in the way.
I had a '17 and now a '20 and they are different. The older has 4 bolts on each side. The new one is tubular, I'm in the same situation, I need a front carrier for a generator.
I found one ! It says for 2500, but I cannot see the difference with 3500.
Exactly. I had one on my 13 that I used for my kayak. The 19 3500 does not seem to work that way. I agree that it is tubular.
Chris
Update. I bought the Curt Mfg front hitch for '19 2500 and didn't work. Some bolts fitted some didn't. I had to cut a 3" square off bottom valance then the hitch hung 6" from surface.
I returned it and built my own mount by using 2" square tubing bolted in place of tow hooks.
Pics coming
