i have one on my full built front replacement bumper, but dont have just the front hitch... its the same height as where the frame connects to the front bumper...
I think that is one of those universal fit receivers made for the back of a truck. The ends are adjustable in and out to accommodate various frame widths. Looks like it was put together with the receiver part upside down to raise it up a little. They are usually bolted together, yours is welded.i just went outside to take a look at it and it is bolted and welded do the frame so its not going anywhere the sticker says 750lbs tongue weight and 7500lbs towing weight thats higher then what has been posted so far but it doesn't have a brand label on it, probably been scratched off sorry
My dad has one on his 06.:yourock:
But I called warn and they told me that hitch wont fit into 06+ only up to 05????? :confused013:
I thought the front part was the same??????
Yesdoes he have the warn on his 06?
You have to drill on any year, AFIK.. I had to drill 4 holes in my 05..It looks like the Warn will fit the 2006 as it does not use any existing bolts or holes. You have to drill 4 holes on the bottom of the frame and install 4 nuts and bolts to hold it there.
