1 - 16 of 16 Posts
I believe I bought a total of 7 quarts and used it all or close to it.. 2.5 qts in the front and 4.5 qts in the rear.
The 7 qts is to do the front and rear diffs.
7 total (will have a little) for front and rear on stock diff covers. Mag cover will add 2-3quarts depending for front and back
I use full synthetic o reileys gear oil . 160k plus of abuse. no problem. Actually i take that back, this rear axle has 15k on it. But the previous on i put 145k w/ no problems. Only reason it got swapped out was becuz i bent the housing down in baja
1 - 16 of 16 Posts
