Hey guys I have an 08 3500 srw and wondering what to do about the front end. I recently had thuren 3inch lift installed. I also upgraded the front steering to the T-style. Installed a new carli steering stabilizer and also had a redhead gearbox installed. The truck drove great for two weeks. But now the steering just feels loose. A bump in the road will cause the truck to go that direction. The highways here have a slight crown to them and can be uneven and it just feels like the truck is all over now. Ball joints are a year old with maybe 20,000 miles on them. Never had a problem before until I did all the work to it. Also it has new toyo r/t 35x12.5x18 on and they were balanced after the front work was done.
What kind of ball joints? If they're moog, there are two lines - OEM replacement and heavy duty. Also there are splined and non-splined models in each line. If that wasn't the first ball joint replacement, and the ones which came out were splined, you have to stay with splined ball joints or dimple the control arms. It's rare for them to go bad in only 20k but it's not unheard of. I'm assuming you're keeping them greased if they have zerk fittings. If not, then that maybe makes it a tiny bit more likely they're shot.
Check the nut on the pitman arm; another thread recently the guy has his pitman arm locknut keep backing off and his steering was all over the place. It was the right part, but sounded like it wasn't fitting perfectly or the "lock" part of "locknut" wasn't cutting the mustard.
Hope this helps.
I've checked the nut seems to be right and the ball joints are napa brand but cant grease them. The little bolt in the grease hole is stripped so I cant get it out
· Decoder Ring Specialist
If all the components seem tight/right I'd second what Rd94yj mentioned about steering stabilizers. When they wear out they can cause the problems you're describing as well.
No I didn't align to thurens specs I was dealing with two separate shops and in a hurry at the time. After doing more research and contacting thuren is when I found their recommended alignment specs.
I also read about the steering stabilizer and how they recommended certain ones. When I emailed thuren support they said the carli was a terrible one to use. At the time though I couldn't find theres. Isn't the carli stabilizer the same as thurens. I believe it is a IFP stabilizer just like thurens.
I have the Carli low mount stabilizers on 2 different trucks. One with stock suspension and one with a full Carli 3” kit and 37”s. I’ve been happy as hell with them. I have better than stock or POS parts store stabilizers.
Thuren has as King stabilizer now, that looks great as well. I don’t think you can go wrong with either Carli or Thuren.
