1 - 10 of 10 Posts
Hey guys new to the forum site I have a 97 cummins transmission leak as I can tell it's leaking in the front dripping off the center of the track bar I'm thinking it's a line but I can't be Shure any advice whould be appreciated.
G.o.a.l.
123456789
Probably the front crank seal and timing cover gasket.
If there is too much oil build up (I had this issue) steam clean (car wash) the engine compartment first. After doing that, I've been able to easily source leaks...
He said transmission, so I assume he can tell the difference?
Found the problem it was the transmission line had a pin hole right were the bracket was on the oil pan cut it and used a rubber hose so far no more leak thanks guys for taking the time to help figure this one out
Yes, I am sure he can. It was late and I completely missed "transmission."
Reactions: Stox225
1 - 10 of 10 Posts
