1 - 11 of 11 Posts
So after 250,000 miles our 98.5 2500 is starting the death wobble. Upper and lower ball joints were done about 20,000 miles ago. I just replaced the steering stabalizer. Where do I need to go from here. Any help is greatly appreciated.
Panhard bar would be what I'd try.
Can I get it from a parts store or is it going to be a factor dodge part?
I don't know if the chain stores carry them or not. You can check their websites. I'm ordering one from Rock Auto.
I haven't ordered it yet, but the one I chose is $83.
Find what am loose and fix. Caster should be as close to 4 if possible. bad tires can cause wobble also. Don't just throw parts without justify. Stablizer is good to check. Looseness in straight ahead position. You feel.
Mine started to about a month ago, and my steering got real loose. The track bar bushing was toast, and after I replaced it, I haven't had that problem. But definitely check for loose components in the steering/suspension.
Sent from my VS920 4G using AutoGuide.Com Free App
Mopar1973Man.Com
Never had it. :confused013:
But I would check for any damage front end parts, shocks, ball joints, tie-rod ends, track bar, etc. Double check the balance on the tires as well.
1 - 11 of 11 Posts
