1 - 17 of 17 Posts
Had it a little with a 2" level, now I have the RC 5" and the front driveshaft humm is annoying over 40mph.. What's been done to solve it ?? Balance shaft? Replace shaft ?
It's had an alignment... So lengthen and balance fixed yours ?
You do not need it lengthened until a 6"
There is plenty of slip joint already built in for anything 0"-5"
I had mine lengthened 1-1/2" for my 6" lift
I would suggest taking it off, and taking it into a good reputable shop. It might need to be rebuilt and rebalanced
Moan most likely is coming from the shaft being slightly out of balance or excessive pinion angle. Pinion angle you can test at home by playing with the caster cams (within reason). While you're down there, go ahead and grease your driveshaft (search the forum, tons of info on this). If those 2 things do not solve the problem, take it to a GOOD driveline shop and have them work their magic.
Um so your a new employee I take it ????
Congratulations mang
Hell I can't even get the drive shaft out !! Front 4 star bolts are killing me !!
Replace those with 12 point heads from ARP. Best thing I ever did on the driveshaft
Reactions: Rhinopkc
Discussion Starter · #11 ·
Sorry it took so long to get back.. I finally got the front shaft out and all my noise from the front end is gone ! So what exactly needs to be done to correct this problem ? I don't have a shop nearby that works on driveshafts, there is a welding shop here that will lengthen it but, are they going to be able and make things better by doing that ? Do I just order a new one online ? I have no idea what to do at this point.. We are supposed to get snow end of next week and I need to do something by then and I hate to just put this one back in..
If the joints feel good you can grease the double cardon joint and pull the rubber boot off the splines, grease them really good and put it back together, that took care of mine. If the joints feel bad I would price out a new one vs. rebuilding yours.
Please don't take it to a welder.... that will solve nothing at all. It needs to go to a driveline shop so they can inspect it and tell you whats wrong (all driveline shops have welders too ;) ). This is one of those situations where it needs to be done by a professional and there is very little you can do at home short of changing out some u-joints and greasing.
What's your zip code?
Discussion Starter · #14 ·
74604 .. Someone said maybe in Wichita?
If your gonna go custom , get a double doube Cardon. One on each end.
1 - 17 of 17 Posts
