1 - 2 of 2 Posts
I'm replacing the u-joint on the differential side of the front drive-shaft. The bearings did not want to go in... I figured rock auto made a mistake, so I went up to Advance and grabbed another u-joint, making sure it was the right part. Same story...
I measured the driveshaft ID and the ujoint bearing OD. The u-joint is .07" bigger than the driveshaft.
Does anyone have a part number that they know for sure is compatible? Has anyone had this issue before?
Any advice is appreciated
Thanks in advance,
Adam
IIRC, the diff side should be a 1480 joint. I may be thinking the axle joints, so if it's not a 1480, then it's a 1410..
1 - 2 of 2 Posts
