I am attempting to do my upper, lower balljoints and wheel bearings, but I noticed my front brake caliper mounting bolts were badly rounded prior to removing them. I was unsure of the size, but an 18mm fit the best. I tried to remove these rounded bad boys, but they are too badly stripped.
Now? What are my options to remove these? I was going to order new bolts, then cut these off with a cut off wheel. I would like to hear some better ideas prior to attempting this. I have a large easy out, but not sure if this is the route to go.
Thank you,
Keith
Thank you,
Keith
