1 - 3 of 3 Posts
Hi guys. I'm converting my dodge to used Dana 60 F350 knuckles, brakes and hubs. One spindle spun outer bearing. Called junky yards around, nothing. car-part.com - has new one for $450, wow... What's my options? Can you tell by the picture if I can reuse it? Good bearing going in and out pretty easy, almost as easy as second good spindle.
I see some guys use punch on it to hold new bearing better, or locktite of some sort, or even dana 50 spindles the same??? I just don't see ford guys talk about it much. Is that not common?
Appreciate your replies.
1ST GEN
Replace it.
Reactions: Russ Roth
Agreed. That thing is junk.
*Could* you re-use it? Sure......will it cause problems for you down the road......most likely yes. So why bother? Get a new one and be done with it. $450 now may save you more than that in the long run.......
1 - 3 of 3 Posts
