Okay guys I have been reading around the site and I understand there are more free mods than what I have done. All I have done, is crank the starwheel all the way and slide my #6 fuel plate. Ive read about the AFC, what is that and how can it be done? Also, any other free mods I can do. I have read that with free mods people are pushing over 300 hp and 700 tq. Last time I dynoed I didnt have the BHAF, slide plate or turned pump and I pulled 260 hp and 570 tq. I am somewhat mechanially inclined so any help would be appreciated!!:beer
what does cranking the starwheel do and slid the #6 do.. and how do you do that.. and what is it.. lol
thats how some men get power instead of plugging something in
CVX try disconnecting the pressure line from your waste gate. instead of 20 psi i now have 35 psi boost
Tech Specialist
Tighten the starwheel, back the preboost screw out, make a #100, modify the AFC, add a 2095 plug, bump the timing, shim the governor springs or get a GSK, shim the overflow, get a boost elbow and enjoy. That should put you in the 350hp range. Capable of 450 but only the gods seem to be able to pull those numbers off
got the #100 plate slide a bit forward, starwheel cranked, AFC gutted, boost elbow done, putting GSKs and the DDP3s in this week as well as bumping the timing and getting a fresh built trans and triple disc convertor :) . what is the preboost screw and where do you think ill be standing power wise?
sorry for the tread hijacking hahaha
PVX i have the mods done in my sig except the DDPs arent in yet and the turbo is boosting to 40psi, so watch that stock turbo ahahhaha
