Well, after getting almost done, after I installed the boost gauge, which went ok, I have the FP gauge (autometer electric) screwed in to the banjo bolt. I plugged the harness into the back of the gauge and ran my hot and ground for the lighting. I started it up and the gauge went to 9 psi and stayed there. I then revved the engine up and still stays @ 9-10 psi. Any ideas on what may be causing this....did the standard checking the ground and what-not...
I also noticed that the autometer sending unit does not screw all of the way into the banjo bolt..it gets tight after about half way or so. I checked for leaks and all is ok as far as that goes..
Any ideas guys????
Any ideas guys????
