upon removing the turbo from my 94 12 valve i found that the first stage intercooler pipe had oil residue in it and the groove in the boot between the outlet and the pipe had oil sitting in it.
(i had originally removed the turbo just to permanently block the waste gate (due to only bein able to build 12 pounds of boost at WOT uphill) so any advice in this area would be awesome! what is the best way to permanently fix it closed? thanks!)
is it time for a rebuild? the turbo spins great and is tight with no end play or side to side. what yall think?
should i overhaul the entire turbo?
thanks fellas in advance! ima beat this sucker one day! lol
