1 - 19 of 19 Posts
Does anyone know where I can find info on exhaust sensor wiring diagrams, Have a friend that thinks he is Einstien, and can build a homemade box if he just has info on what wires are what, and what they send back to computer?:popcorn:
All you have to do is fool the 3 EGT sensors in the exhaust to think they are at 1150 to 1200* constantly. Total of 6 wires. All black. Install the correct resistor and you are good to go.
What about the O2 sensors and the pressure lines??
The pressure lines can be removed and the O2 sensors are left alone, installed. The code comes from the pressure lines not being installed. Should only be a soft code though.
What type of resistors are needed do you know?
That i do not know. I havent pulled my box apart. It works so i am not gonna mess with it. LOL!
Banned
If you can somehow find the wiring scematics of the system you should be able to see what resistance it is in that resistor, I think, and then find the right color coded resistors. If memory serves me right they all start from the gold ring side, should be four colors. Been a while since Ive been to school for diesel mechanics (tractor) though.
chris
500 ohms puts the sensors at a 1028 degrees
Banned
Discussion Starter #10
So do you put the same on all three? Or should the ones in front of the DPF be higher ?
I believe they are all the same.
Discussion Starter #12
Wouldn't the rear O2 sensor still show the dpf to not be working properly?
Discussion Starter #14
Connected on the box that is mounted on the tranny, so like just put a hose from one outlet to the other?:thud:
Discussion Starter #16
Do you have the schematics for the pressure box on tranny?
Discussion Starter #17
What about the o2 sensors!
You're gunna need some kind of special magic for that. I just use the edge. Yes all three EGT sensors need the same resistance.
Discussion Starter #19
Got it solved for now! Thanks!!!!!:peelout:beer:peelout
1 - 19 of 19 Posts
