Ok, while my truck is in pieces in the driveway, a little history, When I bought my truck it didnt have fog lights, I bought the dodge factory fog lights and wired them in, I did it all how the directions said and they worked, but only when the headlights come on,(I wired the little purple wire to the headlight power wire) I know thats right, but I want them to come on when the marker lights come on. So I pulled it apart. Does anyone know which wire would be the constant power in the marker light wires, I am assuming the black, with brown stripe is ground, but there is also a white with yellow stripe, and a white with green stripe. If I had a test light or volt meter I would be done, but I have neither. Help please.
**Or can I just wire the purple wire to the battery so they come on with the switch regardless of headlight marker light being on. I dont really want to do that because I will forget they are on.
