1 - 2 of 2 Posts
So we where cleaning out the shop at work today, slow as he**. We have a bunch of old flywheels cause we used to be a machine shop as well as a truck shop. I was told to throw them all in scrap and came across a new flywheel marked "B series". heres the measurments, the machined surface is 15" across, 4 sets of two pressure plate holes. the two in a set are 3 and 11/16 center to center, from one hole to the other one directly across is 14" the pilot bearing hole is 1 and 3/8 of an inch. does this sound like a 6 speed flywheel, the starter ring is at the very back of the flywheel on the motor side. if this is a 6 speed flywheel can it be used on my 5 speed when i do a clutch and just put a 13" clutch in it or not? I will post a few pics in a bit
Discussion Starter · #2 · (Edited)
My Bad
After i took the measurements i noticed the dowel pins and the 10 hole for the crank bolts. guess i let the b series tag convince me too much. this is a 99-03 PSD flywheel correct? How much are these worth? $300? anyone know where to sell one?
1 - 2 of 2 Posts
