My 2014 Ram is acting a little weird, it will randomly no crank no start which has move more into all the time. It appears the ECM/PCM is loosing connection to multiple modules. I am trying to not just throw parts at it. This is what I am seeing on my Autel MS906 but granted this is the first time I have used it so I am not really seasoned with all I can do with it. But here is where I will start.
The truck cranks fine, if I jump the starter relay it cranks right over. The sense voltage for the relay to trigger it to kick the starter over though is only receiving 4VDC with the key turned trying to start. I am wondering if the ECU or the TIPM is bad but I dont wanna just throw parts at it and expensive parts at that.
So here is what I am seeing in each module.
PCM (Powertrain control module) 2 Faults
U113E Stored Lost Com with Intelligent Battery Sensor (I am pretty sure this is bad and needs replaced but shouldnt cause all these issues.)
U010CPending Lost Com with Turbo Control Module
DTCM (DriveTrain control Module) 1 Fault
U0100 Stored Lost Com with ECM/PCM
ABS (Anti Lock Brakes) 3 Fault (No issue witht he trucks brakes)
U010000 Stored Lost Com with ECM/PCM
U010200 Stored Lost Com with TC Control Module/4wd
C211B92 Stored Ignition run/start preformance incorrect operation
IPC (Instrument Panel Cluster) 3 Fault
U10000 Stored Lost Com with ECM/PCM
U013700 Stored Lost Com with Trailer Brake Control module
U011400 Stored Lost Com with Final Drive Control module
Radio
U01000 Stored Lost Com with ECM/PCM
SCCM Steering Column Control Module
U01000 Stored Lost Come with ECM/PCM
Any help would be greatly appreciated. Also my ECU is "unlocked' with a bullydog tuner for the early EFI Live tunes...I am guessing I will have to redo all that if I end up need to replace the ECM?
All gauges and temps operate and read correctly.
2014 Ram 2500 6.7 CTD SLT
Batteries?
def not a battery issue, 13+ v and had jumpers on it, something not communicating just un hooked all connectors on TIPM single pin was starting to corrode and arc put some diaeletric grease and put connectors back on and cranked and started right up (5 min ago). When i wrote orginal post it wouldnt crank very intermittent and weird. A friend that use to be a dodge tech told me the TIPM acts as the network switch per say where all communications goes through it. When it does crank it starts right up so definitely not a battery issue.
13V? Seems high. I could see 13V one second after taking a battery off a charger and not connected to anything. Sitting there after a few minutes it might be 12.8V if it's in really good condition. Connected, a bit lower. Ideal way to measure suspect battery voltage is to already have the hood open and check them a couple hours after leaving the truck alone. You don't want to do anything to wake up the modules like opening a door, unlocking the doors. Or disconnect one and isolate the vehicle leads and then check the voltage.
Well that was with jumpers the batteries are 12.4-12.8 when i measured each individually unhooked from each other. its not batteries.
UPDATE:
I believe it is fixed. I ordered a new TIPM/PDC when I found the corroded pin. The truck hasn't not cranked since and has com with all modules that it was randomly loosing before. Moral of the story if your 4th gen is randomly losing communication between MULTIPLE modules and the ECM its most likely the TIPM and dont freak out thinking your gonna need a 1300$ ECU and figure out how to unlock it and get tunes on it again.
