1 - 12 of 12 Posts
I don't really know alot about performance in the diesels. I already have a straight pipe on my truck but what would be the next upgrade i need to do to get some power out of my truck?
Intake. Let it breathe brother. BHAF is the cheapest way.
:agree2:
You've opened up one end of the engine, now open up the other!
SuperDuperMod
if you don't have them you need guages, especially a fuel pressure guage. guages first, then you can go from there
I'd go with the ICEBOX!!! You can find that by PM-ing jbarker or Duluth_Diesel on this site. Great setup at a Great Price.
Yeah, I have the icebox/filter/toob, but I looked at it as an investment. Do a search for BHAF if you're planning on going economy, check out icebox if you want a built system.
Why do you need a fuel pressure guage if all you have is intake & exhaust? I didn't think you needed guages unless you are running injectors, & chips???
SuperDuperMod
on the 98.5 -02 trucks the injection pump is really needy, run it under 8 psi for long and your looking at a new 1000 dollar injection pump, stock lift pumps are real weak, first thing every 2nd gen truck needs even stock is a fuel pressure guage. Even stock trucks should also have a pyro and trans temp guage if your towing alot, most guys on here will tell you the first upgrade you should do to almost any truck is a good set of guages.
I didn't catch the he has a 2nd Gen. What about the 3rd Gens, you think it needs a FP Guage too?
i second that man i have a 2000 and the guy before me built it ran it an then put a aftermarket fuel pump on an now the injection pump is really weak:thud:
SuperDuperMod
not a big 3rd gen guy here, but i believe alot of guys run rail pressures guages.
1 - 12 of 12 Posts
