first is going out
595 2
not that is a big deal but first gear well it didnt grind out its like it slipped out at first i had to push it harder in to first and its like the gear slid more and more out till when i put in in first now it like the teeth are just touching and tink off each other just out of reach to grab any word of wisdom will help thanks
1 - 3 of 3 Posts
I put mine in 3rd gear before putting it in 1st to stop the clutch and countershaft from spinning...goes right in.
I do the same thing for reverse.
How often do use 1st and at what speed do you attempt to down shift to it.
The only time I use 1st is towing my 5th, and it is still only useable up to about 5 mph, and that is with 3.55's!:shock:
1 - 3 of 3 Posts
