I am thinking of fire ringing my head when I put my valve springs in where or who can i get them from and what brand should I go with ? I guess I'll need a new head gasket to is there one that is better than the other ?
Why are you removing the head to install valve springs?I am thinking of fire ringing my head when I put my valve springs in where or who can i get them from and what brand should I go with ? I guess I'll need a new head gasket to is there one that is better than the other ?
The guys down at II said that is a big pain in the:butt: with the head on so that made me think about doing the fire rings since the head was coming off. I talked to II and they quoted me 1500.00to fire ring the head, install my valve springs, new rocker studs(I don't know why I need those but they said that it is a good idea), and gaskets. I did some checking around and I found a guy 150 miles away that will fire ring the head, install my springs, clean up the valves, port and polish the exhaust side, and gaskets for 1200 he has got a good reputation and is also a cummins freak so I think that I am going to go that route just need to save a little more mooolah:$:Why are you removing the head to install valve springs?
you don't think that it is worth doing all that ?IMO, Install the studs and swap the springs without removing the head and call it a day.
i've read/heard of alot of people just doing what bbram said and running a fair amount of boost, no 100 psi or anything like that but some good #'s. and it will save you alot of :$:.you don't think that it is worth doing all that ?
Unless you are planning on some serious power. No I don't think it is worth all that. :thumbsupyou don't think that it is worth doing all that ?
i wouldn't go over 40-45 psi just to be on the safe side with head bolts.Not to hijack this but roughly what do studs cost? I think im gonna have to look into some as im pushing the 40psi range with my current setup and don't want to blow anything up.
40 is just a guess It might be even higher. My guage only read to 35psi :CRY: I'm guessing 40-45 is the very top end on what it will handle?i wouldn't go over 40-45 psi just to be on the safe side with head bolts.
