Arp 425s will hold down over 65psi at 135# torque. 90 psi with orings. The arp 625s will hold 125psi with orings. Don't get fire rings.
oh look, a bunch of arbitrary , pulled from god knows where, regurgitated numbers.....Arp 425s will hold down over 65psi at 135# torque. 90 psi with orings. The arp 625s will hold 125psi with orings. Don't get fire rings.
Why did you shave the pistons?My head is off.. I got whats in my sig, i revuilt my motor and shaved piston about .0015 ..
Will arps hold down 45-55 psi? I do t want to ahip my head if i dont have to..
This is a tryout.. I plan on pulling but i want to start somewhere haha.. Just local events and a nice dd to have fun.. Im planing to hit 550-600 the. Il go with a dragonfire vp and bigger turbo setup..A better question would be what's your expected power output, do you plan on heavily loading the motor, any injectables, etc? Not what pressure what blah blah.
I have a machine shop and since pistons were out of the motor why not? I like to try stuff lol.. If it takes a shizz il go mahle depending on quality of the block!!!!Why did you shave the pistons?
All those are numbers from crazy Carl.oh look, a bunch of arbitrary , pulled from god knows where, regurgitated numbers.....
there is no SPECs for what will hold what :rof
You want to put some $$ on the line to back that up? LOL.Just giving you a hard time. Btw I have fire rings and no problems here buddy.Arp 425s will hold down over 65psi at 135# torque. 90 psi with orings. The arp 625s will hold 125psi with orings. Don't get fire rings.
Crazy Carl's numbers. Not really anybody who would know any better I don't think.You want to put some $$ on the line to back that up? LOL.Just giving you a hard time. Btw I have fire rings and no problems here buddy.
To the OP, I blew my head gasket externally right up front puking oil with stock bolts retorqued to #125, Quad ADR,7x.014's,and a stock turbo @ 35psi regularly. Its a gamble any way you look at it. I learned a hard lesson
Sent from AutoGuide.com App
Yeah. Just pointing out, it is hard to give a direct number as theres more to it IMO. My divider is ported big time, I now run Fire rings,Haisley studs,CPP 110 springs,Haisley billet HD pushrods,and porting on exhaust sd of the head and a 67mm turbo so thats pretty much solved my drive pressure problem.Crazy Carl's numbers. Not really anybody who would know any better I don't think.
It's drive pressure that blows gaskets anyway. Port the divider n try to get as close to a 1:1 ratio as possible.
Some more great advice....It's drive pressure that blows gaskets anyway. Port the divider n try to get as close to a 1:1 ratio as possible.
O god, what have I done this time?Some more great advice....![]()
Lol......I've held 85psi just fine with the 425's, but I also ran 75psi on stock bolts for a year.oh look, a bunch of arbitrary , pulled from god knows where, regurgitated numbers.....
