Spent part of Sunday putting in the Vulcan 2 mic fuel filter and the Smeding intake horn.
Both these companies were very easy to work with.
The Smeding horn went right in. Lined up with the intercooler hose and the oil dip stick very well.
The Vulcan kit went in easily. I wound up spinning the filter base 180 degress so that the input side is to the front of the rig and out flow is to the rear. That allowed very easy bends on both hoses, particularly the exist hose to the high pressure pump. Should be very easy to work around to replace the filter.
No problems with either kit other than needing another set of hands installing the two fittings on the bottom of the OEM fuel canister.
I'm not much of a wrench guy but enjoyed getting this done.
