01 4x4 2500. 625 headstuds, 188/220 cam, 7*.0095 injectors, Borg Warner S369SX-E 69/73, 1000HP 47RE
I am about to purchase a new engine for my truck but I want the engine to be able to make 850-900whp reliably. I don't give a **** if it takes nitrous to make that (which it shouldn't). The engine I'm looking at has new exotic head studs, 200hp injectors, haisley connecting tubes, big iron oil pan, billet tappet cover and freeze plugs, scheid so vp44, and Keaton machining fuel plate block off.
I plan on putting in a 188/220 Hamilton cam, extreme duty Hamilton pushrods, Hamilton 103# or 110# valve springs, and ARP rocker bolts. I also plan on putting a fleece coolant bypass kit on.
Question (#1) should I go with a steel or a cast cam? Should I get a cam retainer with it?
Question (#2) which valve springs should I go with and should I get titanium retainers as well
Question (#3) are the rocker bolts excessive?
Question (#4) will the scheid pump support 6*.018 or 6*.020 injectors?
Question (#5) I want it to lope a bit, what size injection lines should I buy?
Thank you all in advance!!
AND FOR ***** SAKE I AM NOT PPUMPING IT! ITS TOO EXPENSIVE AND GOES WAY BEYOND MY POWER GOALS
