I bought the K&N intake system for my truck and bought an Amsoil replacement filter for it. I know alot of you other guys are running this same setup or stayed with the original K&N filter. My question is; What did you do with you filter-minder? Did you leave it in or plug the hole? I want to take it out and plug the hole, in fear of it coming loose and dirt being sucked through the hole. If you plugged what did you use? Thanks
Side note, do you have to be a payin member to post in the tech section?
