This is my experience installing a VB and TC on my truck.
Hopefully, it will give you some insight into what this modification requires.
A little history may be in order here.
I originally was trying to save for a fully built transmission, but soon tired of waiting for $6000.00 to drop in my lap, and determined that SOMETHING was better than nothing, and better to do it sooner, than later. So I looked into a Torque Converter and Valve Body. My transmission has about 9000 miles on it, and hopefully, the addition of the TC and VB will allow it to last longer, operate cooler, and put more HP to the ground.
I gave Gus a call at Farmboys Diesel, and although he recommended doing more than the TC and VB with the HP and TQ goals I had, all I could scrape together was the funds for the TC and VB for now, especially in today's economy. Gus is a vendor on Cummins Forum, in case you haven't heard of him. He takes good care of his customers, is knowledgeable and just an all around great guy to talk to and do business with. Although I purchased the parts a short time ago, I had difficulty creating time to do the Install and write up. Work has finally slowed, so I decided to dive into the install. This procedure was performed on the truck in my signature line. Wherever possible, I reinstalled bolts and nuts once the pieces were removed to keep track of them and where they go.
The first thing I do anytime I'm wrenching on the truck, especially when disconnecting harnesses is involved, is disconnect the batteries (Usually the negative terminal).
Next, I blocked the rear wheels, to prevent the truck from moving when the drivelines were disconnected.
The front driveline at the front Axle pinion requires a T40 bit to remove. I removed it at the front differential first.
This allowed me to swing the driveline down, and access the driveline bolts at the Transfer case, which are 5/8". Spin the driveline until the bolt at the top can be accessed with a socket, repeat for the remaining 3.
This is a shot of the “Elusive” front driveline grease Zerk. The Zerk is for the CV, not the U-joint.
The only way it gets grease is if you put it there.
Grease it using a needle fitting on your grease gun.
The rear driveline is disconnected at the rear differential, by removing 4 -15mm bolts, then pulling the slip shaft out of the rear of the transfer case.
Note the large size of output shaft on the transfer case.
Next, I began removing all the connectors to the transmission and transfer case. (My transfer case is electric shift).
This is the 8 pin connector going into the VB... Note I have spliced a wire into it for a TC lockup switch...
I’m not sure why, but when I disconnected the neutral/Park safety switch connector, a little ATF fluid came out..
The connector that gave me the most trouble was the VDO shift position sensor on the Driver's side of the transmission.
There are 2- 1/2" bolts that need to be removed to gain access to the connector release mechanism.
The little red tab is the release mechanism
Next, I removed the breather tube for the transfer case.
Next I removed the shifter linkage, first, by prying upward on the shifter pivot, then by removing the bracket on the transmission. The top nut is 18mm, the bottom bolt is 3/8"
With the harness out of the way, I began removing the transfer case nuts. 14mm is a tight fit, 9/16" is a correct fit. I found it necessary to use both wrenches to loosen and remove the bottom nut by the transmission mount, there just isn't enough room to get at it, and it was the most difficult to remove.
After removing the nuts, I separated and removed the transfer case from the truck. It weighs about 110 pounds, so get help if you need it!
There are several brackets attached to the transmission Bell housing, and I decided to remove the bolts that hold the brackets on first. Bell housing bolts are 9/16" I did not remove all bolts at this time, just the ones with brackets associated with them, including the transmission dipstick bracket.
