I got one for cheap last year and flipped it after using it. Going to try a bulletproof one nextThe only hitch i need good for 20k and never had a need for a WDH in decades of towing hundreds of trailers View attachment 975680
Way overpriced for the same thing in my mindI got one for cheap last year and flipped it after using it. Going to try a bulletproof one next
I would have kept it if it had slightly more drop - not quite enough for the equipment trailer we have, otherwise I would have.Way overpriced for the same thing in my mind
The receiver is bolted to the truck. The hitch would be your weigh safe unit.I’ve got an 8” drop weigh safe 180. I needed a 2.5 receiver in a hurry and it was the fastest thing I could get my hands on. The only issue I’ve had is the locking hitch pen doesn’t want to come unlocked after being on the truck a while. Tapping it with a hammer and some liquid wrench gets it working again.
Grade 8 with nyloc here also. Also use anti rattle clamp…would take someone awhile to remove and would have to have socket and wrenches. Piece of pipe will snap a locking pin in a heartbeat…I tried it myself.I’ve never had good luck with locking pins. I have yet to find a good one. I’ve been using a grade 8 bolt and nut, at least itll slow them down. Those locking pins all you need is a pipe to snap them.
^What he said!The only hitch i need good for 20k and never had a need for a WDH in decades of towing hundreds of trailers View attachment 975680
As I understand, the main benefit of those hitches is they lighten your wallet sooo much that you gain a significant amount of useable payload back! LolHensley Arrow for me. You won’t understand the difference until you use one.
Yeah, careful with the reducer thing. They are mostly good for wallering out the pin holes on the receiver and bending hitch pins.I’ve had the same couple hitches for years, I mostly use an old solid shank mount with a bolt on 2-5/16 pintle combo. No idea what brand it is, it’s been re painted more then once. I’ve been meaning to pickup a new mount so I don’t have to use that stupid reducer anymore.
Admittedly they require regular maintenance (lube) in the rust belt.I’ve never had good luck with locking pins. I have yet to find a good one. I’ve been using a grade 8 bolt and nut, at least itll slow them down. Those locking pins all you need is a pipe to snap them.
