is the stock replacement fass fuel pump any good? it comes with a 4 yr warranty and im wondering what it puts out for psi
not to say anything bad about ya'll, but to me if someone were to replace the fuel lines from the tank to the VP why not just get a stand alone pump and be done with it?Most idle at around 18-21 psi at initial and settle down to around 16-18psi after that. This of course depends on line size, if you run a DrawStraw and if you are using a big line kit (filter to injection pump).
Some of these pumps seem to be able to hold pressure to support 100HP injectors if the entire line system is replaced, the pump is relocated and a DrawStraw is used.
Dave
I completely agree that there are better (more expensive) options out there. But some guys want a "stock replacement pump" only.not to say anything bad about ya'll, but to me if someone were to replace the fuel lines from the tank to the VP why not just get a stand alone pump and be done with it?
i can see the DDRP if you keep the truck 100% stock, but that's about it....i don't know, just my opinion on the matter...
