1 - 13 of 13 Posts
I can hear the Fass pump running but no pressure. I called Fass they said I may have got some bad fuel. Try changing the filters. I have always purchased filters online. Is there any major auto parts that sell filters I can use on a Fass 150 series pump? What brand and number do they sell? I'm stuck in Perryville, Maryland. HELP!!!
Here is a list of cross references for the FASS 150 Series (HD series):
Fuel (1 1/2-16)
Baldwin BT372-10 (5M)
Baldwin BT372-MPG (10M)
Carquest 85724 (10M)
Caterpillar 3T8642(5M)
Cim-Tek 70032 (10M)
Cim-Tek 70213 (3M)
Donaldson P550705 (10M)
Donaldson P569381 (3M)
FASS FF1003 (Cim-Tek)
FASS FF1010 (Cim-Tek)
Fleetguard FF5588 (10M)
Fleetguard HF 6338 (10M)
FLEETGUARD HF 6601 (10M)
FLEETGUARD HF 6604 (3M)
FLEETGUARD HF 6607 (6M)
Fram P8024 (5M)
Hastings HF779 (5M)
Luber Finer LFH4922
Luber Finer LFH8324
Purolator 7400SAL032F2 (3M)
Wix 51116 (11M)
Wix 51120 (9M)
Wix 51202 (5M)
Wix 51724(10M)
Wix A07A03G (3M)
WS (1-14)
Baldwin BF 1258 (10M)
Baldwin BF1212 (20M)
Baldwin BF1214
Baldwin BF7546 (10M)
Donaldson P551000 (10M)
Donaldson P551001(10M)
Donaldson P558000 (20M)
Fleetguard FS-1000 (10M)
Fleetguard FS-1001 (10M)
Fleetguard FS-1009(14M)
Fleetguard FS-1023 (144M)
Fleetguard FS-1212(14M)
Fleetguard FS1282 (14M)
LuberFiner LFF8000
LuberFiner LFF8011
LuberFiner LFF8020
Motorcraft FD818 (14M)
Wix 33405(14M)
Wix 33406 (14M)
Wix 33522 (10M)
· PA VICE PRESIDENT
I always get mine from napa. I think the older pumps use a different filter. I got 3405 and 1202
There are not many auto part stores around here. None in walking distance. I wasted half the day calling auto part stores trying to cross reference filters. I looked on fassride.com and found a Fass dealer about 15 miles from my motel room. They had the water separator but no fuel filter. I had to talk a taxi company in to picking it up and bring it to me. I filled the new water separator with fuel and loosened the fuel filter to bleed the air out as Gene Brown at fassride.com suggested (I got his phone number off Fass' website). The fuel pressure is now 17 psi. The same as it has been since I installed the pump back it 2008. The truck did not start and it was too dark to do anything else tonight. I plan on bleeding the fuel line at the vp44 in the morning. I will need some more tools if I need to bleed the injectors. I will post my progress again tomorrow. Hopefully I will be back on the road heading to New York. Thanks to everyone that posted the replies.
· PA VICE PRESIDENT
When I changed my filters I had to crack the lines on mine. I always carry a 3/4 or 19mm wrench with me just in case
Reactions: goldshop
Discussion Starter · #10 ·
I purchased the truck new in 2001. I have drove it all over the US. Never a problem not even a flat while on the road. I often carry a toolbox. This time the cab was full and left it at home. That want happen again. From now on my toolbox will be the first thing I load.
Discussion Starter · #11 ·
I bled the fuel line at the vp44 and three injectors this morning. After getting both batteries charged the truck started. I plan on being in New York tomorrow and back home in Texas by Sunday. Thanks again.
Fuel (1 1/2-16)
Cim-Tek 70032 (10M)
Cim-Tek 70213 (3M)
Fram P8024 (5M)
Hastings HF779 (5M)
Luber Finer LFH4922
Luber Finer LFH8324
Wix 51116 (11M)
Wix 51120 (9M)
Wix 51202 (5M)
Wix 51724(10M)
Wix A07A03G (3M)
WS (1-14)
Baldwin BF1214
LuberFiner LFF8000
LuberFiner LFF8011
LuberFiner LFF8020
Wix 33405(14M)
Wix 33406 (14M)
Wix 33522 (10M)
Thank you for posting this all those years ago I just used your list December 2020. Hard to find these numbers...
1 - 13 of 13 Posts
