I know there is a lot of info on the 1/2 & 1/4 issues with this set up and the modifying of the canisters. I don't want to rig up my canister nor put a sump in that's going to be under my tank possibly in the way. I contacted Fass and spoke to them about my concern. They said that the supplied Bulkhead and draw straw should be fine as long as the tank is supported correctly off of the ground when cutting the straw to length. I want to know if you guys had any personal experience with this. Am I on the right path or should I invest in something else. thanks
